Dennis(IA)
Helping a neighbor with his 4000 gas. He was not getting gas to the carburetor. I looked at the tractor and found that someone bypassed the fuel pump on this tractor, so the tank must have a fair amount of fuel in it so gravity can get the gas to the carburetor.
Question: The fuel shut off under the tank does not stop the gas flow. It turns only about 1/2 turn, is this correct or should it turn several turns when going from off to on?
I thought about removing the valve, but this may create more problems.
I found a 12V fuel pump for about $35 this my be a cure for his problem. The old gas lines were cut and pinched, and the fuel pump may not work so this would be a big job.
