Hey folks, was a member here once upon a time but got out of an old tractor for a time but now I'm back. Gave my 2N to my sister and my nephew's wife used it and locked up the engine somehow. Traded for a 600 a couple days ago, boy did I get screwed, my fault, water under the bridge. Didn't run when I got it but looked like it was fixable. Got it running fairly easy and the engine sounds good, trans has all the gears and the PTO works, tires are decent. On the the "major" problem, it is pumping the hydraulic fluid out of the sump and into the transmission case, indicating the pressure tube has a leak. Read a couple older threads on it and people were either sleeving the tube or replacing it. http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ford&th=544876 for instance. Have there been any updates to this situation i.e. new fixes or is this still it? Is the tube from Walt's still the only one available?
