Cleaned up my rotted double bevel rim for old 4000. Wire wheeled, welded, painted. Drilled new whole for valve stem on opposite side. Problem is, new valve stem whole is on flat spot of rim pointing straight in toward center of wheel. Old rotted whole was in a spot on a 45 degree angel made for stem. (No other 45 spots for new whole). When I put tube in, I could tell stem wanted to go on a 45 but was forced straight down, after 2 months tube went flat from bent stem, possible being cut.
Do they make tubes with stem pointing in towards center?
What should I do?
What should I do?
