Need help on 960 front end
pinball
Anyone have some parts for a wide front end on a 960 ford tractor. not sure if the 860 or 900 will work. looking for the tie rod assemblys on the front axle to the underneath of tractor. hopefully close to Missouri. thanks norm
there is 1 factory WFE for a ford N/O rowcrop.
860 ain't a rowcrop. 700 and 900 series are rowcrop ( non offset ).
they use the exact same front ends... and there is only 1 ford factory WFE for those 700/900 and 2000/4000 rowcrops ( not to be confused with 541 offset or 2000 offset models )
I am having a problem finding anything for the 900 but if the 700 2000 and 4000 are the same then msybe I can find those. new holland doesn't seem to have the ones for the 900s. thsnks norm
I GUESS YOU CALL IT STUPIDITY ON MY PART. TWISTED THE BOLT HEAD OFF OF THE BALL JOINT, WASNT MY GOOD DAY. STILL HAVENT GOTTEN THE ROD OUT OF THE TUBE HOLDER. THIS JOB IS NOT GOING LIKE I PLANNED. TRYING TO FIND A PARTS MACHINE AROUIND HERE IN MISSOURI IF I CAN. THABKS NORM
(quoted from post at 07:22:22 08/31/16) I GUESS YOU CALL IT STUPIDITY ON MY PART. TWISTED THE BOLT HEAD OFF OF THE BALL JOINT, WASNT MY GOOD DAY. STILL HAVENT GOTTEN THE ROD OUT OF THE TUBE HOLDER. THIS JOB IS NOT GOING LIKE I PLANNED. TRYING TO FIND A PARTS MACHINE AROUIND HERE IN MISSOURI IF I CAN. THABKS NORM
I had one of those apart a few years ago. It was tough, but I was determined! Plenty of heat and penetrating oil.
