Starts to run rough after about 20 minutes.
On injector pump where banjo nut enters pump, fitting spins at the two hole plate. is that okay? Also when I removed the two bolt plate, I found what looks like sawdust in there. how should I clean that out and is there a filter on the pump? If so where is it located.
Thanks have a great day.
