Ford 532 same as 4600
Jim 777
Starts to run rough after about 20 minutes.
On injector pump where banjo nut enters injector fitting spins in two holl plate is that okay? Also when removed two whole plate found what looks like sawdust in there how should I clean that out and is there a filter on the pump? If so where is it located.
Thanks
