Blowing hyd gasket
Dcmore
New User
My jubilee keeps blowing out the gasket between the piston and lift cover. I replaced the relief valve. Any help would be appreciated.
Be sure that you have gaskets at all bolts or else the assy will be cocked toward side without gaskets. Appear to be missing on two studs here.
Got to use all three gaskets under ram cylinder housing. Got to be same material so all is level. Leave out the two doughnut gaskets and it will cause
it to blow other gasket. Unlevel.
Zane
