My basket case 660 is only getting to the 545 rpm at max throttle.
The parts for the linkage are from a parts tractor of unknown origin other than a 600/800 series.. If ti was a 800 series were they different lengths etc?
I've adjusted both rods per the service manual and it's only around 1800 RPM max/540 PTO line for max. Although,
if I pull on the governor rod well i get more RPMs which I would think should rule out my carb being the limitation.
The only thing I can thing of is that the linkage from the parts tractor might have had different lengths between a 800 and 600 model...??
Any ideas??? other than not getting full RPMs i'm ready to get this thing out and test it out with a mower...
