Wiring Harness
Cheatme
New User
I'm going to put a new wiring harness on my Golden Jubilee, but can't find a diagram. What is on now could be wrong. I'm only going from the starter to voltage regulator to amp meter. If someone can help me get the right terminals correct, it will be greatly appreciated. Thanks, Ron
(quoted from post at 15:17:39 08/27/16) JMOR, does the wiring diagram for the NAA/Jubilee carry over to the hundred series?
Thanks
he hundreds are essentially the same, but the 01's differ in starter solenoids, generator charging lamp vs ammeter, and fuel gauge addition. Then of course the diesels have differences.
(quoted from post at 20:28:33 08/27/16)
Thanks
Thanks again. I'm dealing with an 860 so I shouldn't have much difficulty. You diagram seems easier to read than the one in the I&T manual.
only thing I can think of is your ammeter with terminals vs the NAA loop style ammeter. In your imagination, cut the wire loop & connect the ends to ammeter terminals.
