What is the single spade connector circuit for ? ( as mounted on the motor, its the single connector to the lower left of the of 3 spade connectors with the larger connector with the black plastic cap on a Lucas 81863039R).
When I disconnect that wire, the test light with the bulb illuminated (in-line with positive cable end and + battery post) turns off. Is this a potential source of something shorted or draining the battery ? Both battery and alternator,(CNH dealer reman) are new, installed but not run yet. Factory alternator did the same thing.
