what joystick to use to replace my duel control on my ford 4
moonmonkey
New User
i have a 1963 ford 4000 with a ford factory loader,, it has a vickers vane pump ran off the front crank shaft. my duel controls leak so i want to up grade to a single joystick control to replace them. things i dont know for sure are how many cfm does the control need to be? and at what psi do i need to set the relief valve since its in the loader control valve.
A 20 gpm valve would be plenty, check out the loader valves available thru Tisco and other companies that specialize in ag parts.
Most valves that come with relief valves built in are set at 1500-2000 psi, if you push it much past 2500 you'll be risking blowing lines or seals.
