Vickers pump output....'63 Ford 4000 Industrial
sixbales
Howdy,
Does anyone know the output gpm of a front engine mounted Vickers vane pump on a 1963 Ford 4000 industrial tractor?
There are probably different pumps listed. Volume rating will vary with the thickness of the center section.
Information on Vickers pumps is available. The Model number of the pump will be embossed in the body. If you can get the model number you can determine its output. Many sources on line for the info. Pro-Active Fluid Power at 800 398-5733 can help you.
