perryjosh64
Folks I've recently had to replace my gas tank due to a leak. I'd hope to replace the fuel shutoff valve with one that goes to the center of the tank (old one was a NAA type w/sediment bowl at the rear right side of tank). Old one I had to run rubber fuel line around backside then up left side of tractor to carb. However I've gone through two different center fuel shutoff valves (has two mounting screws and O ring) but both leaked from the seal I assume because it coming from between the shutoff valve and tank. I've tried replacing the O ring, gasket material and Gasolia sealant and still leaks?
Any idea what I'm doing wrong or how to fix it?
I wish they had one that screwed in like the side mount type? Would it be to much of a stretch to run line diagonal across engine to carb with brake line/fuel hose?
