Will it fit?
Trying to confirm if a ford backhoe will work with a ford 3550 tractor. Our tractor already has a the subframe installed.
The backhoe is model number 19 481.
Thanks for the help!
That backhoe should work on that tractor provided the tractor has the proper attaching kit (sub-frame). Measure the width of the main frame of the backhoe at the pins that attach it to the subframe on the tractor and measure the distance between the notches on the subframe that the pins go into.
