Ford 1600 wheel bolt pattern sizes
cdsilks
New User
I have a 1978 Ford 1600 with rear turf tires and smaller front tires. I am wanting to switch to a rear lug tire and taller front tire as to the factory specs of 11-2-24 for rear and 5.00-15 for the front tires, however I cant seem to find anyone who knows what rim size and bolt pattern I need to buy the rims. Anybody know what rims or where I can purchase them? Thank you, Corey
Not sure if the wheels for that tractor were non-standard widths compared to normal wheels for those tire sizes, but 11.2-24 rear tires should normally go on 10" wide rims and 5.00-15 front tires should normally go on 3" wide rims.
I'm not sure on the bolt patterns, but you can measure them yourself. From the parts site it looks like the fronts have 6 bolts, so just measure center-to-center between two bolts that are directly opposite each other. The rears are 5 bolt, so measure center-to-center from one bolt to one that is on either side of being directly opposite.
Thanks for your info. I will do some measuring and see if I can locate some rims since finding any used for this model seems next to impossible.
