marcusmerritt
Ford 2000; 3 cyl. gas; 4/1 trans... my daughter is getting married at a friend's farm and at least some of the parking will be in a grazing pasture. I have volunteered to bush hog the field close to the wedding date and, having not bush hogged in years, would like some advice on setting up the machine on the three point hitch. I have some knowledge of setting it up and I've read a lot about it and seen some videos but would like advice from those with hands on experience. Have read that the front end might want to be lower than the rear so cut grass is expelled. Is that correct and are there any other things to look out for. The field is pretty flat and been bush hogged many times before as well as being cut for hay.
What gear should I use for mowing? My tractor is a 4 speed. I have a drive shaft with cover and the attachment to the gear box is a round shaft with hole for shear bolt. I do not yet have a slip clutch. Must I have one if I use grade 2 shear bolts?
Also, any ideas on the amount of gas the 2000 may use per hour when bush hogging on fairly level ground in medium tall grass?
Thanks.
Thanks.
