Ford 2000 industrial rear engine oil leak Question
Does this tractor need to be split to change the rear oil seal?
Is there anything else internal that could cause an oil leak in this area.
Thanks for anyones input on this..
Ty
In addition, it has an issue with the 3pt. Was working well. Now it is down and when valve is opened to allow pressure to the 3pt and shut off the loader the pressure just screams like it is locked up. Any ideas? Is there a valve that could cause this?
Thanks Ty
Do you have a early 63-64 four cylinder 2000 or a 65-74 three cylinder 2000, the engines are completely different.
If it's leaking out around the clutch housing it could be the transmission input seal or the rear main. Which one is getting low on oil.
I'm not sure what valve your talking about that turns on the loader.
Order yourself a I-T manual from this site or get a factory service manual for your model.
