My 3600 gasser overheats after 20-30 minutes of work. At least a gallon of coolant is expelled thru the radiator
overflow tube every session. I changed the thermostat but same problem. I removed the thermostat, same problem.
With the engine running, thermostat removed, I cannot detect any flow while looking into the radiator . Shouldn't
there be some flow, even when cold? The water pump is turning as it should and is not leaking. Is it posssible
the impeller has dissolved/broken apart? Or is it more likely that the radiator core or block is plugged? I
don't want to have to remove the pump if it's not necessary. Thanks for any help or advice.
