Bern
- Location
- Mount Vernon, WA
I'm rebuilding the 4-speed trans in a NAA with a Sherman over/under auxiliary trans in it. I have a dilemma that I'm hoping to get some input on.
The trans in question was recently rebuilt by some other guy who must have been on drugs. I've never seen such a messed up gearbox. One gear was installed backwards, as was one seal, another seal looked like it was driven in by a large rock, bearing cages were distorted with a puller, the list goes on and on. I'm going completely re-through it.
When I disassembled the Sherman trans, I found that it was missing the thrust washer between the input and output shafts. I have no idea how long it's been gone - whether this last guy dropped it on the ground or if it has been running for years without it. The washer in question is reference #11, part number C0NN-7C343-B. Washer is unavailable new or used that I can find. I was told I was likely going to have to make my own out of some brass shim stock.
After studying the situation closely, it appears that all this thrust washer does is keep the #10 pilot bearing from rubbing on the front face of the output shaft, since all of the pieces on the output shaft are retained by a snap ring #12, and the input shaft is positively retained by the input ball bearing #7. In other words, this missing thrust washer is not responsible for keeping the two shafts separated.
After doing some research, it appears I'm not the only one who has faced this dilemma: http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ford&th=348787
Anyone here ever left it out and ran without it? What would you do in my shoes? Anyone know where I can find this washer? I've already tried Smith's Old Ford Tractors. He has a lot of Sherman parts, but not that washer.
Thanks
Thanks
