Ford 445A Headbolts
Wrico
New User
Does anyone know what the torque is for the head-bolts and is there any pattern for torquing the head-bolts?
Also if you blow a head gasket do you have to replace the head-bolts?
head bolts should be fine.
<a href="http://s33.photobucket.com/user/Joecdeere/media/temp%20folder/scan0001_zpsqedgviwc.jpg.html" target="_blank">
</a>
<a href="http://s33.photobucket.com/user/Joecdeere/media/temp%20folder/scan0002_zps5qkw5glr.jpg.html" target="_blank">
</a>
Beware that those specs are for 9/16" head bolts. If you have 1/2" bolts, drop the final spec to about 110 ft-lb.
Rod
