2 9600
trying to take steering arms off under dash to fix leaks.got puller onwont budge .whats best way toget them off with out damage.. power steering
are you trying to take the draglinks off the sector arms, or the sector arms off the sector shaft?
In either case a 2 jaw seperator should easily pull them.
They can be a bear.
Put your gear puller on it and tighten it up good. Then put a little heat to the arm.
Doesn't take much and it will pop off.
As Ultradog said heat it some with the puller tight It will pop off. The hammer works well on the drag links but not so well on the steering box arms
Boss
hammer works fine on the arms if you know what your doing.
aLL YOU have to do is plastically deform the joint a smidgen.
heat applied there means you should be rebuilding the steering box as you will be cooking the sector seals.
I've never had to heat a sector at off a sector shaft yet... Because I know how to do it with a puller or pulled and hammer.
