Ford 2000 Industrial oil pickup tube broken
kandrelly
New User
Can anyone help me? I have a 1964 Ford 2000 Industrial with a 134 cid 4-cylinder engine. I recently dropped the oil pan, and the oil pickup tube is completely broken off!!!!! I need to replace it, but I can't find one to buy anywhere. I can find the ones for the 8n, 9N, etc, but they don't appear to be the same. Mine has the cup at the end, but only 2 bolts hold it onto the pump, not 3, like i keep seeing. Is there one off of another tractor or car that would fit? I don't know what to do. ANY help would be greatly appreciated. Thanks!!!
do you have a local welding/fab shop? Take the two pieces to someone good with a TIG and you'll likely be out $25 (or if he's working out of his garage, a case of beer)
I can probably try that, but the tubes are collapsed where it broke, must have bent before it broke. But thanks for the suggestion!!
Apparently there aren't many people with this problem. Hopefully I can figure something out. I'm at a loss.
Would anyone have a parts diagram so I could get the part number and maybe cross match it to something that would fit? I found one for the 8N, but the pickup is different.
(quoted from post at 20:23:29 07/29/16)
here's the parts diagram for the oil pump for a 1964 2000 Industrial (use 2130 as the model number when doing parts lookups for your tractor):
[u:36ae1a03cf]http://partstore.agriculture.newholland.com/us/parts-search.html#epc::mr62715ar361488[/u:36ae1a03cf]
The part number for the pickup tube assembly is C0NN6615B, which is showing as no longer available on partspring. Messicks shows that part number as being 3-5 business days, which usually means that they can't get it either.
tractor-part.com shows a number of salvage yards that have used available:
[u:36ae1a03cf]http://www.tractor-part.com/parts/c0nn6615b[/u:36ae1a03cf]
