emontague49
New User
I recently purchased a 58 Ford 841 powermaster and am having issues with the hydraulics. Issue is/was hydraulics were not lifting all of the way. Would have control set to all of the way up and would still have 6"-10" of play. Could not run a plow as I do not have sufficient clearance.
Bled the hydraulic pump to remove any air, then messed with the control lever thinking that it might not be positioned properly. After doing these two things the arms do not lift at all. I checked the hyd fluid on dipstick showed overfull but when i looked into the fill port looked to be very low.
Any recommendations on what to do/check next?
