Gallagherm78
New User
So I'm looking for some helpful answers on this tractor ford 7000 with a 7710 motor tractor runs great everything works fine but the hose for the inside the hydraulic tank keeps blowing apart thinkin that's from using to light of hose but also wen u use the hydraulics the valve block whines like it's plugged somewhere almost like a valve is sticking not quite sure how to remedy we also have a 6600 that has same hydro setup and it works fine didn't know if anyone had an idea on why it would do this. But the main issue we have with the 7710 is it seems to be lacking power runs great on idle and all the way to full throttle but it won't blow any smoke at all wen under load and dies out I was mowing hay with a 9 ft new holland hay bine and I could hardly keep it running while on flat ground in second or first gear and it wont even puff any smoke at all thinkin fuel problem but not sure wat to do about it tractor has lucas in line injection pump any suggestions?
