Ray Fregoe
New User
I just picked up a 62 4000 select o speed. I went and drained the oil out of the tranny and cleaned the drain screen. Now there is a constant dripping from the drain hole when I filled it back up. I looked at the drain screen when I had it out and I changed the o ring on the end of the drain plug. What really seems odd is that there was no o ring further in to keep any oil from leaking out the drain hole Its a very poor machine fit only. Does anyone else have problems with dripping at the drain screen? The only solution I see is to put a rubber expandable plug in the drain hole.
