Limbhangers
Ford 2000 8 speed diesel 1974 model. I keep chiming in on here every couple weeks as I get time to work on this project a little at a time. Tractor is not back in the typical shape I like to keep my equipment (everything working), but did do some cutting with it this past weekend. Did real well on tight woods roads with a 5 foot cutter some of my hunters left behind. I can now see why people like these little machines. I have never owned a small tractor like this but I am use to older equipment, so I didn't miss any of the bells and whistles.
Here's the question - Generator isn't charging and wiring is in pretty bad shape. I'd rather just fix while I'm ahead so I think I'm just going to re-wire with a new wiring harness. I'm looking at this conversion alternator on E-bay. I believe it is a one wire AC Delco:
http://www.ebay.com/itm/201626487559?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
I'd rather have an alternator than generator, what am I missing here as far as hooking this up? Will this directly hook up and run through the stock voltage regulator, etc. It doesn't have much of a description but looks to be the same kit that others are selling.
Thanks,
Thanks,
