Awlknottedup
I posted this earlier adn received several replies. Thanks to all who replied. Several indicated my description was not very good so here is more of what I learned.
I need the front plate on the SOS transmission for a 1965 Ford 3000. This is the input in the front of the transmission where the transmission oil pump is located. CNH calls it a Plate Assembly, oil pump adopter, P/N C5NN7B471A. Cast, about 18" in diameter. The one I have has a crack in the oil pump housing and leaks badly.
One question is are the 3000 and 4000 SOS the same?
