801 Diesel after sitting 8 years. An experienced mechanic found rust in the old fuel while draining the tank filters and pump body, and decided the pump needed a rebuild. Then mechanic went home to Washington.
Pump rebuilt, I show up to install.
Rolled engine until #1 push rods loose, set it to 20 degrees BTDC on the flywheel, pump gear looked right with the larger segment of the gear/drive facing the engine (per a different post here on YT). Pump went right on, pump timing marks aligned in the window, installed. Lines cleaned, installed, purged of air, fuel up to the injectors, air bled out several times.
Cranking with half throttle (cover handy at intake to keep from running away), glow plugs working. NADA. Engine breath out the exhaust, but no smoke.
Gave it a whiff of starting fluid, it seemed to pick up in cranking speed, but no start. With no sign or smell of fuel in the cylinders, ether is pointless as well as ill advised anyway.
As I understand engine timing, and the way this engine was timed, there's no chance it could be 360 out, right? If I accidentally had cylinder #1 at the TDC #4 cylinder (1-2-4-3), then pushrods on #1 would be tight as the exhaust valve would be closing, and the intake opening, right? So that's out of the way.
Then the pump gear drive plate with its groove cut through, rotates at half engine speed, and would always be in the same phase position....would always be in the unique position when at #1 TDC. So when the pump with its eccentric shaped drive key fits right on the drive plate correctly, that's the only way it could go...confirmed by the timing mark in the pump window aligning.
So, throttle in half position, cranking, fuel spurting at injector nuts, then tightened and more cranking.
Any ideas? I'll keep air bleeding and cranking but at what point do I start to investigate other issues?
