Just restored my grandfather's 641 and just about finished with exception of rear engine oil leak. I used the paper wedge seals and I thought they swelled too fast and didn't seat all the way so I dropped the pan, verified the neoprene seals were installed in the correct orientation and removed the paper seals. Cleaned everything up then applied a little moto 1 to the mating surfaces and reinstalled the block. I then forced ultra grey into the cavity and stuffed with ultra grey coated cotter rope. I saw sealer extrude out the sides of the bearing block and cleaned up the excess. Started her up and it ran fine for 20min no leaks. Took it around the yard and it's dumping oil again. I noticed the oil was overfilled about an 1/8" above the line and drained the excess, still leaking. My oil pressure is about 55psi at rpm and only drops to 45 or so idling. I'm ready to be finished with this project and only live a hour from Hobo. May need to pay him a visit.
