The Clutch Kit listed here is 9-inch. But some people say take it apart first, it may have a 10-inch. NAA serial number indicates mfg in 1954. Should I open it up before ordering parts, or will it be 9-inch? Any advice about replacing the clutch is appreciated.
Looking at previous posts, people have suggested pulling the flywheel and replacing the Rear Oil Seal, since the tractor will be opened up. I'll order the seal with the clutch kit. Will there be a problem pulling the old seal out? Does it need a special tool? Does anyone know what part # the seal is?
Also this tractor has power steering. Was that offered '54 NAA, or is it aftermarket? Oil leaks like crazy at the steering box. While I have the tin and gas tank off, I'll take a look. What should I look for? THANKS
