14-59 mower
RLBurke
I picked up this mower, all complete except the breakaway attachment bracket. I am trying to mount this on an 850 or a 9n. Both tractors have issues due to a loader on the 850 and an ARPS track setup on the 9n. Makes it difficult to get the brakeaway bar attached under the axel. Any one know where I can find the attachment bracket?
I have one on my 850. I use the pin on it for the horizontal stabilizer on the 3-point. If you were to send me a bracket to replace it with, I would send you what I have.
The stabilizer pin is at a different location between a 9N and 800 so you need to decide which tractor you will be using it on before buying a bracket.
Thanks for the help. In case I need to build a bracket, what is the vertical measurement between the two pins on the bracket I pictured??
