dk0402
New User
I have a for d 4000 need help the fuel Injection pumpwent out and I can't find one anywhere it's part number is dbgvcc429---1aj it wont start on its on spray a squirt of starter fluid in and it starts with the second spin of the motor as soon as it runs out of starter fluid it dies so I know it runs
Ford made two completely different 4000 tractors, so you should always start off by telling us whether it has a 3 cylinder engine or a 4 cylinder engine.
That's a big leap from only fires on starter fluid to "the injector pump went out".
It could simply be air in the system that needs to be bled out, or clogged injectors, or a clogged filter or gunk in the fuel tank clogging the outlet to the shutoff valve.
If you haven't done so already, I would replace the filter(s) and bleed the system first. While you have the filter(s) out check the fuel flow from the tank to the filter housing as well.
(quoted from post at 07:06:12 07/11/16) Ford made two completely different 4000 tractors, so you should always start off by telling us whether it has a 3 cylinder engine or a 4 cylinder engine.
I think he did! He gave us the injection pump #. That number can only be a 4 cylinder pump.
A little more history would be good here. Was it running and quit? Has it sat for awhile since it's run properly? Is it a machine you've had for awhile? Or did you just acquire it?
In other words, what do you mean by "the injection pump went out?"
