Ford Jubilee Industrial
LarryM
I was talking with a guy who was buy a Jubilee out of a junk yard. He said it was an industrial and that is why it had spots for headlights up in the front of the hood instead of along the side. He also said they put a 192 CID engine in them from the factory. Is this true? I am also wondering if they made a 900 industrial with a bigger engine in them as well.
Most likely an 1801 series with the cast grill if it's got headlights in the grill. Those came from the factory with a 172 ci engine, the same as the 800/801/900/901 series. Ford made an industrial engine that was 192 ci, but that was only used on non-tractor industrial applications, like generators, pumps and wood chippers. A number of the 192 ci industrial engines have found their way into Ford tractors over the years, but none of them left the factory that way.
Another guy who don't know what he's talking about. No industrial jubilee. 192 was later in the sixties. I have a 192 in an 841, a jacobsen tractor and just put one in an 860, none installed at the ford factory, industrial engines were never installed in tractors including the 900 which had no industrial. Holes it front of hole made by someones drill, not factory.
Kirk
The headlights were not in the grill. They were in the hood up high in the front corners versus on the side like most I have seen.
(quoted from post at 12:01:03 07/12/16) The headlights were not in the grill. They were in the hood up high in the front corners versus on the side like most I have seen.
Could be any model from an NAA/Jubilee up through a 4 cylinder 2000/4000 then without knowing the stamped numbers and not having pictures. As others have said there was no industrial Jubilee, and there were no 4 cylinder tractors that left the factory with 192 ci engines.
There were some 3 cylinder tractors with a 192 ci engine but they had square hoods and looked nothing like a Jubilee. There was even a couple of industrial models, like the 4500 gassers made from 1/1/65 through 3/31/68 were industrial tractors that had a 192 ci engine.
