4500 ford power steering pump
mrfabjr
I have a 4500 back hoe that has a Plessey UK pump. I looked on this site for a kit to repair a leak going into the oil pan but could not find one. Am I overlooking it or do they don't list it? Part number C5NN-3N675-D
This site has lots of parts that are not listed. I have called them many times looking for parts and am amazed that they are avaible rite here.
That is a casting number or an internal tracking number used during the assembly of the tractor, not a part number that is useful in ordering parts after the tractor was sold. You need to go through the parts book or parts web site to determine the part number that you need for the seal kit. Does your power steering pump use the main hydraulic reservoir up in the nose of the tractor that's used by the loader and backhoe, or does it have its own reservoir integrated into the body of the pump?
The part number is on a tag on the pump. That is where I got the Plessey name and part number. It uses the reservoir from the front pump for the power steering and loader and backhoe. I have a picture of the tag but I am not able to download it for some reason. Guess iI dont know how!
Thanks
Floyd
As I said, the numbers that came on parts on assembled tractors were generally not the part numbers that you would use to order a replacement part. They were only useful to the folks that tracked them as part of the assembly line operation. They used completely different numbers for the parts departments at the dealerships to order them by.
The original part number for that pump was C7NN3A674F and has been superseded by part number 81816585.
The seal kit for that pump is part number DHPN3A674A and should be available from any New Holland dealer for around $120.00. Aftermarket kits that claim to be direct replacements for that kit are also available for considerably less.
