This message is a reply to an archived post by Shannon Robinson on May 31, 2012 at 13:49:28.
The original subject was "Help Installing new diesel injector pump on 69 Ford 4000".
I just read your posts. Hope you get this and can offer help. I have a 4000 3 cyl diesel with a CAV pump. The bell housing casting is 4GOIC C7018. I think I was told that meant a 1974, but maybe 64. The pump has been leaking for some time, primarily at the pump from the line to the NO 2 cyl. We replaced the line yesterday, with a part from Yesterday's Tractor, and the leak from the pump to the line is even worse. Is there an internal replacable washer or something in the pump port which should seal the line? I would appreciate any help. Thanks
