7710 Ford with Apl-325 front axle
fordman81
I have a 7710 Ford with an Apl-325 front axle. I'm needing universal joints. The only info I can find from New Holland is complete yokes. Does anyone know if you can replace just the u-joints?
That's the info I see too.... and at 1300 per side I would imagine you want better options....
I guess if they're buggered I'd just knock them apart and see what size the cups and crosses are. Surely something will cross to match it.
Other option would be to check with either Sparex or Fawcett Tractor. Sparex carries some ZF parts. Fawcett's carry quite a lot fo stuff for
those old axles and have decent pricing too... however I have no idea if they supply those double cardans.
Rod
Hi Fordman, just looked in my UK Sparex book on Ford parts.
For a Ford 7710 with a ZF APL325 front axel it lists a S33614 U/Joint
and the size is 27mm x 70.5omm. Hope this helps. MJ
