Ford PA rims part number?
Vptracguy
New User
I'm looking for the original part number on 1955 Ford Power Adjust rims. My center disc's are good, just the PA brackets are rusted out. Mine are the 4 bolt and 4 notched brackets, not the spin out type (I think I'm saying that right). 13.6x28 and 12.4x28 is what I have. The 12.4x28 rim is about gone.
I called my local parts dealer and New Hollard shop - no luck.
Any info would be appreciated. Thanks!!
Those rims are no longer available new. There was a seller on eBay that had rebuilt ones for sale, but he no longer has them listed on eBay nor in his eBay store.
You'll have to get a blank rim and salvage your existing guides and weld them to the new rim. The valve stem opening may have to be heated an pressed to a proper angel as well.
Hey wheel shows replacement rims. Not adjustable. Uses the 4 bolts in center to mount. I have 1 good one in west central tx.
I found one on CL in St. Louis but I'm in east TN. My guides are
pretty much gone. I'm thinking using a standard rim and welding on
four mounting brackets for the disc. I've got enough scrap around the
shop, just no scrap time. Hopefully, this rim will last through this
garden season.
Thanks for the info!!
Thanks for the info from all. The welding project turned out great. I fabricated and welded on mounting tabs to the rim opposite the 6loops then welded it all up. I've put about 40 hours on the tractor since and the rim is good as new. Going to do the other side this fall.
