Front Weight
60 Fan
Recently came across a Front weight for Ford. Trying to identify what I have here. Weight is about 20" wide and about 8.5" high with Four Mounting Holes. Sits convex on the ground with casting numbers facing up. Casting numbers FoMoCo and I believe to be
O5NN 3A370-B. Did not have scale to determine actual weight.
Attempting to determine what this fits and approximate value. Thanks in advance for help.
20" wide is pretty big. big pillow weight.
how about a picture. you know what they say about pictures..
Unable to post picture however, there is an Ebay ad depicting two rear weights and three front weights painted bright Blue that look very similar to the one that I have here. Search under Ford Tractor Wheel Weights on Ebay.
If they look like the ones in the photo most
folks here call them pillow weights.
I think they're about 80 lbs.
They fit 6000, 3 cylinder 4000, 5000, 7000
and their newer sisters - 46/56/66/7600.
that's not much to go on.. i hit ebay and see a blue set of front wheel weights and front bolster pillow weights.
Thanks for replies from all. This does indeed look like the depicted pillow weights.
Next question, what might ONE be worth and would someone want or be interested in ONE? Located West of Cedar Rapids, Iowa.
