I had power steering fluid leaking out the top of steering column on my 1973 Ford 3000.
I removed the upper steering column and found the upper trust bearing pre-load spring washer had broken apart. I continued to remove the control valve spool assembly (all the plungers and springs fell out before I could note were they all came from) also noticed the upper thrust bearing lock-nut was loose on shaft. After inspection I found one of the plunger springs was broken off shorter than the other two. I continued disassembly but the bottom race of the lower thrust bearing would not slide off the shaft because of scoring right below the lock-nut threads. As I proceeded to remove the steering adapter housing, the roller pins fell out of the upper shaft bearing. I decided at this point I needed to replace the shaft and rebuild the steering column and gearbox.
I was able to get all the seals and bearings from the upper column and adapter housing removed but I having some trouble getting the lower shaft roller pin bearing removed from the bottom of the gearbox. It looks as though the lower shaft roller pin bearing has bottomed out against the bottom of the gear box casting.
If any one has any advice or ideas on how to pull that lower roller pin bearing or remove both the steering side gears with their bushings and seals from the gear box, I would greatly appreciate the help.
Thank you in advance for any help you can provide.
-Robert
-Robert
