RSFARMS
New User
HAVE A 5000 FORD TRACTOR RELEASE BEARING LOCKED UP & BURNT FINGERS OFF PRESSURE PLATE . THE QUESTION IS THE PTO SHAFT & DRIVE HUB SPLINES ARE ALL BUT GONE HOW DO YOU GET THE SHAFT OUT OF THE TRANS. THANKS FOR ANY HELP IN ADVANCE.
(quoted from post at 16:33:27 06/22/16) THANKS IS THERE ANY THING TO BE CAREFUL OF WHEN SPLITTING THE TRANS FROM REAR
Make yourself a lifting plate to bolt onto the top of the tranny in place of cover. Drill a hole in plate for heavy eye bolt where the weight center will be. Then you can lift the tranny with whatever you have.
