tex prexhurst
I am converting my 6 volt to 12 volts. I have previously converted an 8n and a Farmall h. In those two, I used the old coil, and just put a Chrysler big ceramic ignition resister in series with the coil. This worked fine. Is there any reason that I can't do this with my 2000? People talk about varying resistance (Ohms)for 12 volt coil, but won't the resistor simply reduce the 12 volts to 6 volts? I was told that is why Chrysler used the resistor on their cars.
I did change the bulbs to 12 volts.
Thanks,
Tex
Thanks,
Tex
