ag 720 cylinder rebuild
wonl2
New User
Hello forum members, I have a Ford 1700 with a AG 720 loader. The tractor has been sitting for 12 years or so and I'm slowly replacing things that are worn. I want to rebuild the 4 cylinders on the loader but have no Idea where I can find the parts. The bucket rod diameter is 1" and the lift rod diameter is 1 1/4". Any help will be appreciated. Already looked at Tractor Supply, no go. Thanks in advance!
Phil
You can tear down the cylinders then match up the seals and packings at an industrial hydraulics or seal place such as Baum Hydraulics or Zatkoff Seals and Packings. You might also be able to match them at a local hydraulics service shop or even your local New Holland dealer.
Another thing, the Ford loader for the 1700 was model 770, is the AG 720 some other brand? Seal kits for the 770 are readily available from Baum, or even Ebay or Amazon.
Sounds like you have a Ag Tech brand loader, the current name of the company is ATI and is located in New Holland, PA. They should still have the seals but a hydraulic shop near you should be able to match them up.
