Loader hyd pump drive shaft and hub where to find??
old
So I was moving some big round bales of hay today with my 841S with loader and went to lift one and heard this clattering and the loader did not go up like it should have. I climbed off of it and looked and the hyd pump drive shaft was turning then stopped turning and then started turning again.
So I need to find some place that sells the hub and shaft. It is a 6 spline type shaft. Years ago I would just call one of the local tractor dealers but both Dale and Jack have since gone out of business and both are also 6 foot under but then the last time I had to replace one was well over 15 years ago.
I did get a bit lucky and was able to realine the shaft and push the pump forward a bit more so as to get a few better splines in the hub but I know that is just borrowed time before it stops work altogether.
Thanks
One reason I know what I need it I kept the last one that went out on me and had it next to this desk
TISCO has a bunch of that stuff which means you can buy it here. Spline count, shaft diameter, length. Hub configuration will be necessary as well as somebody on the other end of the phone that can understand.
external link Parts or a good A&I dealer can get you a new shaft and hub.
The replacement will most likely be a 10 spline unit.
ABC1812 and ABC1814 should be the right Steiner part numbers for the 800 series tractor. Just make sure the dimensions will work for you.
Don't need to replace the pulley since it is already in place. The hub yes and the shaft. Shaft is 9-38 inch long and 10 spline
