Where or what parts to get to repair/replace a rear remote?
Andy4600
One of my Ford 4600 rear remote hookups is leaking constantly when I hook into it. I have tried replacing o-rings, with no success. Where is a good place to get new couplings? Which couplings should I get? I tried to look up the parts with New Holland, but they seems to be discontinued. Is there a good aftermarket rear remote hook-up kit anyone would recommend?
Thanks.
I like pioneer.. but you can hit surplus shop and shop.
I personally like to replace QD's as a matched set, so the male and female are compatable.
I was looking at something like this:
It is a 9500-4 coupler kit.
Any experience with it?
FYI...
There are HIGH FLOW Couples and regular couplers... will not matter in most applications, but if a high flow is needed, you must replace it with a high flow. Pioneer makes all types of iso connectors. They make cheap generic iso,,,, , connect under pressure iso, and high flow iso.. the prices are VERY different for the three types. So you may want to try to match what is there pending on your application.
