Jeepjeepster
With the amount of traffic this site gets I imagine no one remembers my original thread. Bought a piece of property that came with a 1975 ford 3400. Seems to be in overall good condition.
Replaced the fuel pump for good measures, replaced the rubber fuel lines where someone had cut the hard lines (maybe someday Ill find some good used hard lines) and replaced the fuel valve on the bottom of the fuel tank that was leaking. Ran the tractor for an hour or so and the power steering kept running out of fluid but I didnt have any visual leaks. After topping it off 5 or so times I finally realized something was wrong. Just happened to think about the engine oil so I checked the level. WAY too high! Almost coming out of the dip stick! Before I started it was perfect.
So anyway, took the power steering pump off and I guess Im looking at replacing the input seals. I cant find anything on this. I bought a service manual that covers 65-75 ford tractors including the 3400 but it only shows the remote reservoir, doesnt show the integrated pump/reservoir which is what this tractor has. Anyone have any tips for replacing the input seal?
Does DHPN3A674B for the seal kit and C5NN9030D for the filter seem right?
