So I was moving some big round bales of hay today with my 841S with loader and went to lift one and heard this clattering and the loader did not go up like it should have. I climbed off of it and looked and the hyd pump drive shaft was turning then stopped turning and then started turning again.
So I need to find some place that sells the hub and shaft. It is a 6 spline type shaft. Years ago I would just call one of the local tractor dealers but both Dale and Jack have since gone out of business and both are also 6 foot under but then the last time I had to replace one was well over 15 years ago.
I did get a bit lucky and was able to realine the shaft and push the pump forward a bit more so as to get a few better splines in the hub but I know that is just borrowed time before it stops work altogether.
Thanks
One reason I know what I need it I kept the last one that went out on me and had it next to this desk
Thanks
