Ultradog MN
- Location
- Twin Cities
I've had Ken's 4400 at my place since last fall. It's only been started a couple of times in the last 8 months.
So I go to start it cause I need to move it out of the way. Won't start. No fuel to the injectors.
Grrr.
Bleed the filter. Bleed the pump. Both are good. Still no fuel to the injectors.
So I go to pull the top of the pump off to move the metering valve.
Jeez, what a PIA to get in there around that loader. You can NOT see in there.
So I got the metering valve freed up - by braille - and got it started and moved it.
But I must not have gotten that slide bar in right cause it's leaking like heck.
Gonna have to go back in there. But not now.
I'm done whining now.
I think if I need to do some loader work I'll rent a skid loader.
Grrr.
