1964 4000 lift cover piston cylinder
wedgehead
I removed the lift cover and i have a ? .
Do I have to remove the piston cylinder housing from the lift cover to get the piston out of the bore. There is a pin that stops the piston from coming all the way out that is part of the linkage.. Do I remove the housing are do I remove all the linkage .
Thanks
Though you could probably disassemble the linkage in order to remove the lift cylinder piston without removing the cylinder from the lift cover, you will likely find it less time consuming to simply remove the cylinder from the lift cover and use (very) low air pressure to pop the cylinder out of the bore.
Dean
O-rings.
Do yourself a big favor and use the correct O-rings upon reassembly.
Dean
