Ford 1320 Cracked Flange
Spudm
I wondered why this tractor was losing fluid, and then I noticed a crack in this flange on the right rear wheel axle. Question is: What needs to be done to repair or replace this flange? Thanks!
You'll have to pull the entire axle housing off of the center housing and remove the axle shaft retaining nut. Then you can remove the 4 bolt flange and the axle shaft.You have to pull off the outer bearing to get the flange off. The axle housing doesn't use a gasket where it connects to the center housing. Just get the surfaces clean and dry and use a good silicone sealant.
Adrian
