mohammed
New User
hi need help to solve my ford 5610 problem.tractor starts and goes for about 20 mins and suddenly the clutch starts to slip eventhou its engaged in a gear it still doesnt go.let it cool for 5mins it goes again and stops after 20 mins.checked the clutch plate and pressure plate looks ok anyone ever came across this.i suspect its the dual power unit but not sure.
I assume you had the right amount of free play at the pedal? Sounds like the tractor may be split now? I think you maybe should have checked the dual power hydraulic pressure when it was running. If it's split I think you maybe able to test the DP with air pressure.
